Soulja »
https://forums.nicoclub.com/soulja-u11149.html
Thu Oct 28, 2004 10:09 pm
While its still connected to the cat, I would loosen the bolts attaching tha manifled to the head. You might be able to shift the header on the head a slight amount, giving you a couple more mm's of clearance. You could bang the floorboard up a little with a hammer, or you could try torching the header and bending it a slight bit for some more clearance. I would still wrap the header in exhaust tape anyway, it will cut down on the heat, and increase the efficiency of the header. Or you could fill your old mounts with urethane or window weld and swap them in after it cures. And you shouldn't need to disconnect everything to swap out the mounts, just unbolt the engine and trans mount, jack the engine up enough to remove it.
