spider_slayer wrote:ok, i have never posted in here before. i have an s14 with an sr20det and i'm looking to run the megasquirt fuel computer. someone told me that alot of you guys use it. first of all...what do you guys think? secondly, how did you guys go about wiring it inot your existing harness? was it pretty complicated?
I am running a Megasquirt n Spark, on my L28ET in my 71 240Z, I would highly recomend using it as a full stand alone and making a new harness from scrathc, as the MSnS uses a MAP sensor and IAT not found on the s13 and doesn't use the MAF, and you'll have less issues finding problems if you built the harness, check megasquirt.info and msefi.com for more info
