float_6969 wrote:Alright, so last night I was playing around with compressor maps, and I think that the T3 super 60 is a great compressor setup for the CA. (for my goals at least) I know that a T28, is a T3, but it's just the plain 60 trim wheel. The super 60 map looks much better IMHO. So here is what I'm thinking, and I want to know what others think about this.
I'm thinking about picking up another S14/S15 turbo. Probabally an S14 because it'll be cheaper. Get a Super 60 wheel and have it (properly) installed on the compressor side. Then get a stock CA turbine side housing with the .49 A/R. My thought is that this would give the turbo good response, but still move some air.
So what do you guys think? Am I just an idiot, or is this the CA equivalent of the Disco Potato?
I was unaware of this. I'm not doubting you, but are you sure?mbmbmb23 wrote:...the S14/15 has a T04B compressor side...
that sounds extremely large.. got any outside info on where you got this ?float_6969 wrote:I was unaware of this. I'm not doubting you, but are you sure?
It uses a T04B compressor HOUSING. The 'B' is the smallest T04 housing there is. S14/15 = T28 compressor wheel in a T04B housing with a T25 exhaust wheel in a T25 housing.float_6969 wrote:I was unaware of this. I'm not doubting you, but are you sure?
Yes.float_6969 wrote:gotcha, so it's still a T3 60 trim wheel?
upper 200-lower300. Less concerned with peak HP as I am with a broad powerband and good response.Not_a_sr wrote:what are your power goals?
