sorry to burst your bubble but it probably will not pass emissions. i beleive if you live outside of phoenix area you only have to pass saftey inspection.250sx se wrote:ok no problem i just have to take it to smog testing to get tags i hope it passes
i understand that u dont run a PCV as i do not either. But u have nothing pulling the gases from your valve covers... You need to connect the two braided hoses comin off the valve covers to a T and then to one port on the oil catch can. Then use the second port on the catch can to go to the intake which will create a negative pressure in the catch can. Thereby pullin the gases out of the valve cover...250sx se wrote:i welded the pcv hole on the valve cover closed no need for it any more
doesnt look to me like he has a breather filter on it at all which is why i gave him suggestions on how to fix his systemDarius wrote:<Frustrated that people still don't understand the PCV system after there have been a dozen threads on the topic>
OP your system is fine as long as the catch can has a breather filter on it to allow the can to breathe.
this is correct.Darius wrote:<Frustrated that people still don't understand the PCV system after there have been a dozen threads on the topic>
