I have a recirculated bypass valve that is dumped back into the turbo intake after the MAFS (which I think would cause it to run a bit lean since the MAFS isn't reading this air) I've never had a problem with this bypass valve (Turbo XS), but I can't hear the friggin' thing anymore ever since I ditched my cat, which isn't a bad thing because the noise got kind of annoying after a while--
See pic:
http://www.eniety.com/pichost/pic/128-2895_IMG.JPG
Starting from the left side of the vacuum setup
Line that comes from underneath the intake manifold, which I hope is where my boost reading is coming from.
First "t"-line goes from here to a pressure switch that is activated at 6.75 psi to turn on the alcohol injection-- The white T that is further up in this line, to which the blue/black hose is attached runs to the right side of the car through the firewall and is where I get my boost-gauge reading from--
Second T on the right of that vacuum mess is attached to a hose that is attached to the top of my bypass valve--
Far right side of that T is connected to the OEM FPR.
On a side note--Do I need to worry about the vacuum line blowing off the FPR because this line now sees 10 psi of boost (it was previously disconnected when I had an aftermarket FPR)? The vacuum line didn't seem nearly as snug a fit as the other hoses even though the line was made for the FPR--I tie wrapped it just to make sure it'd stay on there (I don't have any hose clamps small enough for that hose), but I'm still wary of it possibly blowing off. All of the other lines I've never had a problem with.
