Zerep wrote:i read the install on the d3 in the howto section and i was wondering if i didnt hook up the wire to the cluster or the one to the brake light what would be the effects to the system. im planning on gettting the avic f and dont want to take my steering column apart if i do have to can i use a wiretapper for the cluster i saw the doctor use one on the brake light but not on the cluster.i got the an aftermarket deck already so i got the harness for the radioit was the base deck before that
ok, the pics on the cluster removal wee taken from the avic411 site... all of the rest of the pics were mine...
I used taps for both the cluster and the rear brake light
1. if you don't tap the speed sensor wire, then your navigation ill NOt be as accurate, and you will only be using the built in gyro to setermine speed, acceleration, etc. But you can still use the unit without tapping this wire
2. If you don't tap the reverse wire, then you will not be able to view the reverse camera view either when driving or when backing up, pending you ever decide to install a reverse camera. But gain, your unit should be functional without hooking up this wire.
Just curious as to why you are going with the avic F series.... too many bugs IMO!
