I have had both Tein H's and Eibachs on my car. I recently sold my Eibachs because they were too low, especially in the front.
I miss the improved handling with the Eibachs but the Tein's have better ride quality. Also, the Tein's are kinda floaty and the rears are higher than the fronts (I don't like this).
So, after taking a good look at the the rear springs I could see that they would fit nicely in the mounts even if you cut them (cut the bottom).
So this is what I did, I took a cutting tool and cut off "1/2" turn. This will lower your rear about .5 inches (1/2 inch) and level the car.
Not only IMO does it look better, the car handles better, is more stable, and no longer floates. Better intial turn in too. Extremely close to the Eibach's in terms of handling but better in terms of people in your car without bottoming out and smoother. As an added bonus you can still can pull up to curbs.
I highly recommend this cheap upgrade.
