Victor »
https://forums.nicoclub.com/victor-u94029.html
Wed Sep 28, 2011 11:49 am
The second replacement of the J30 timing belt is supposed to be done at 210,000 miles. I assume that is a conservative figure and the figure could probably be extended for another 10,000 miles, maybe even more.
I don't know how much it would cost to have it done at a dealer or independent. but I saw figures mentioned anywhere from $400 to $900. If I bought the cheapest stuff available at Rock Auto I could buy a belt, three pulleys, and a new water pump for around a hundred dollars. If I bought the top of the line of what they sell it would cost a bit over $300. Has anyone replaced the belt themselves, and if so how long did it take? I would have to do it crawling under the car with the front wheels on ramps.
The alternative would be not replace it and drive the car until the belt breaks or some other major, expensive to fix problem occurs. My car now has 202,500 miles on it, and has not needed any expensive repairs in the last 25,000 miles that I owned it. Looking at the records I got from the previous owner the car has never needed an expensive repair. In fact the biggest expense so far was a new set of Bridgestone Potenza RE960AS Pole Position Tires that cost me around $480 including installation.
I really don't want to put any big money into the car if possible because the car is approaching the age and mileage where a major problem could happen at any moment, or I may get lucky and the car could keep running relatively trouble free for another ten or twenty thousand miles.
Everything on the car now works properly except the power door locks are flaky, and the windshield washer. I fixed my dashboard dimmer switch problem with a three dollar dimmer switch I got at Pick a Part. I fixed my ABS fault light problem with a used relay I got for $2 at the same time.
