The tank maintains a slight vacuum for emissions reasons, not to assist the pump in moving fuel. I can't see how lack of a vacuum would hurt the fuel pump in any way.drewnashty wrote:Could this leak have caused an intermittent lack of fuel pressure to stall the car and maybe damaged or put wear on the pump due to lack of seal and vacuum?
Be sure to check for signs of overheating on the printed circuit board pads that are soldered to the leads on the power transistor. The transistor runs hotter when the fuel pump starts to fail, due to higher current draw. The pump also draws more current if the fuel filter is obstructed, so replacing the filter is a good idea.I also removed the fuel control module which looks fairly new; I removed the cover plate and the solder points all look good.
If the threads in the tank are also stripped, a new screw might not grip any better than the old one. If so, you might be able to use a self-threading sheet metal screw instead.I'm wondering if I should just get a new screw to fasten the pump securely to fix the leak
You could advise her to keep at least half a tank of fuel in the tank at all times, in order to help keep the pump cool.I'm just worried about the pump putting excessive current draw on the fuel control unit if the pump is going out, especially with 110+ degree weather right around the corner here in Phoenix.
Make sure if you decide to hack it and use a self tap screw that its not longer than the screw that came out of the tank.Skibane wrote:
If the threads in the tank are stripped, installing a new screw might not help. If so, you might be able to use a self-threading sheet metal screw instead.
Partly, but it's also cooled by being immersed in fuel. It will run hotter if it's not immersed.Infinitiguy19 wrote: Another member on this board says the fuel pump is cooled by the fuel that runs through it. Is that not true?
The pads on the control unit and the power transistor look new with no signs of overheating, warpage or discoloringSkibane wrote: Be sure to check for signs of overheating on the printed circuit board pads that are soldered to the leads on the power transistor.
Definitely.You could advise her to keep at least half a tank of fuel in the tank at all times, in order to help keep the pump cool.
I got some new screws and fastened them down just enough to be snug. They were about 4 mm longer than the originals, that was all I could find at the Home Depot. Will this be a problem. They didn't run out and kept fastening with ease until flush with the pump surfaceInfinitiguy19 wrote:
