240eclipse wrote:ok well im looken to get around 400 hp then ill be happy....pretty much got about 3-4g after the motor..... probly going to take it to the track maybe make it a show car.. i know enough where i can rebuild an entire motor so i think a swap should be cake......and tools i work at a autobodyshop/garage so its all good
Cool.. At least you know what your are doing.. We get entirely too many kids who don't know how to do an oil change asking these rediculous questions.
400whp is achievable on stock internals for Rb20, RB25, SR20, and probably even the KA24. So you shouldn't need to drop too many dollars on building the engine itself.
You will however, need to spend money on fuel, airflow, and engine management, as well as a nice size turbo.
SR20 is just less than $2000 to buy, while RB20 is a little more than $1200 to buy (on average) plus you'll need either custom mounts or a R32 xmember. The RB25 will run you around $2k as well.. but require a mount kit and driveshaft, making it the most expensive of the bunch.
Even though the RB20 is cheaper to acquire, it's more expensive to mod. You can get 400whp out of it.. but most experts say that's about all you want to try with stock internals. I've heard of more from some people.. but I think the rule of thumb is to keep at 400 max.
It's an age old arguement.. . SR vs. RB.. Basically comes down to what you want..
SR (+) easier to swap, easier to wire, easier to mod, cheaper parts and better aftermarket. RB20 (+) more unique, better sound, smoother feel,
SR is also a bit lighter if that's a concern to you.
RB25 is a better engine than both of the others. More torque, more hp potential, the beefiest trans you can find, etc.. But, it's more expensive as well. If you want to push 400 and still have room for more hp.. it's a great engine. It will cost you $3k+ to install (engine, mounts, driveshaft, wiring, misc, etc..)Another $1500 or so should get you to 400whp.
Good luck!
