To pull or not to Pull?
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
i need a picture of a coupe or hatch (preferably hatch) with any type of 17 inch wheels with a 17mm offset for the rear. Did you have to pull or strecth the fenders, and if you did how far were they pulled?
dickie
Car: Killer Turtle
thats something that the width of the wheel would help us answer... unless you mean that they are 17" wide. in that case, you will need to remove your fenders and quarter panels entirely to gain clearance.
240RB1
92 Nissan 300ZX Z32
9.5 inches wide sorry i didnt sleep much yesterday
dickie
Car: Killer Turtle
sounds like nice wheels. with a +17 offset, you might be looking at a nice pull, i think chrislis and 974-240sx run or ran wheels that had close to those specs (at least i think so!). you should search their posts regarding wheels to see for sure.
240RB1
92 Nissan 300ZX Z32
thanks for the help
sip
Car: Impreza STi GC8
RX7 twin turbo
1974 Mazda RX4 3 rotor
2014 Forester XT (Baby Hauler)
www.drluc.ca
!240RB! wrote:i need a picture of a coupe or hatch (preferably hatch) with any type of 17 inch wheels with a 17mm offset for the rear. Did you have to pull or strecth the fenders, and if you did how far were they pulled?
Also, whether or not you need to pull depends entirely on how low you want to go. Although something tells me you are going LOW.
I also think you should pull it out to give it a little flare, just for esthetics. It doesn't look right to hav a wheel sticking 2-3 inches out of a straight lined body.
gumby74
I have a pair of 17x9.5 +20 that I used to run. Old OZ Monte Carlos with a 245/40 tire and 2* neg camber. At about 2" of fender gap the sidewalls would rub. I am thinking if you went lower than that, you would not need more than 1/2" of pull to clear. Your tire size and camber setting will also determine how much more space you would need.
