TO NISTECH! KA FL30A IG SW FUSE PROBLEM
jgauspohl
Car: 97' S14 SR24VET
92' S13 S14 SR20DET
90' Golf GTI
91' S13 siltruck project
here's the deal this 96' ka has been swapped over into a sohc 89' s13...ran fine and idled perfect took it on a test drive and died twice. Found out it was the FL30 Ignition switch fuse replaced it...blew again ...car will not start up now but will turn over. I'm thinking it's a relay or something not sure maybe someone knows about this or has had this kind of problem before.
NateDogg
Well I doubt Nistech frequents this forum you should put this in the Nissan Mechanic forum. I know the S14 KA uses a different ignition system than the S13 KA24DE. Maybe you have to convert it to the external coil type?
jgauspohl
92' S13 S14 SR20DET
90' Golf GTI
hehe I figured that one out right after I posted ...tracked the wires of the ignition system they ended up rubbing before and the kid hadn't told me...soldered them...fixed
