SO... I NOW have a 95 240sx SE 5-speed. I am planning on an RB swap and here are the details:
I will most likely go with a mount kit, with the custom driveshaft and just buy the motorset as opposed to the front clip.
In conjuction with the standard RB swap it will go together with:- Metal headgasket, most likely power... possibly cometic if they make one.- ARP Head Studs- Full Stainless Steel 3" Exhuast- 4" Intake with Blitz Filter- PTE (Garret) NICE FMIC (3.5" Thick).. Supports well over 700 horse. All the intercooler piping and prolly a Tial BOV.- PT-63 Turbo: 63mm 56-Trim Compressor in a T04S cover, and not sure on exhuast wheel... I think its around p-trim in a .63 A/R T3 Turbine Housing. Big Shaft CHRA. Rated at like a max 700-750 Horse.- Some Clutch... Undecided, may go with RPS or ACT Extreme. A 300zx NA turbo correct?- Walbro 255HP, Blitz Injectors (Not sure yet if 550 or 850)- Either Z32 Air Flow Meter + AFC, or more likely something custom like a blow through Hot-Wire (maybe GM?!) with a controller I make.
Now the question I have is... Will the standard RB25DET hold.. I've opened up SR20s before and WOW, if they make their sixes anything like the fours it will be fine. I plan on eventually running like 25 - 30 psi (granted with race gas) with my turbo and it should make around 600ish horse, maybe 500-550 at the wheels.Daily driving I'll keep it down to probably 15-18 on pump gas and would assume it would be about 400ish to the wheels.
Otherwise I would definately consider the Neo6 motor. Has anyone actually verified that the internals are stronger on a Neo6? Also this thing about the injectors being top feed... Hell that almost sounds GOOD to me, in general top feeds are cheaper, especially If I could get the Mitsu style top feeds to work... then I would just run good and cheap delphi injectors. What else is different about that motor? Honestly the price isnt too much different, I think if the internals are stronger that is justification enough.
As far as the VVL or VVT... whatever it is... I'm assuming it operates a lot like VTEC and would literally work with either a VAFC or with a simple switched 0 or 5 volt signal correct? Hell that would take me no time to create a variable RPM based "window switch"
I guess at this point I am almost leaning twoards Neo 6, simply because for the little extra in price I get, stronger internals (if verified), better VE in the motor, a newer motor, possibly better injector pricing?!
Anything I am over looking here when making this decision (regular vs. neo)? ... Anything missing with the setup?
I have just got into this stuff and I know a lot of you have been in it for sometime now, so I am definately open to what you guys are thinking,
Murray <- Now a 240 owner
BTW, I apologize in advance for any abreviations or DSM lingo I have put in this post... That damn crap is embedded into my brain like the plague after like 5 years of dealing with them.... Don't worry it will be gone soon enough. I am glad to be part of the Nissan community
