to much boost?
A home for 1983–1989 300ZX owners!
winez31
Car: 1993 s13 ka24de
ive read everything about z31 boost levels, but today it was 40 degrees and i was running 13lbs and no detonation on 93oct gas. do you guys think i will be fine at this boost level. also ok all i had done to my car was 10 lbs open down pipe and no pwr steering or ac or clutch fan. and some how i managed to run a 13.3. any idea what is done to my car that i dont know about that could make me run this. haha i sound like such a noob but o well.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
NOOB!!! haha
You got two bottles of NOS in there? j/k man
I think you should be ok with 13lbs as long as everything is in order and you're detonation free.
winez31
alright thanks man
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
unless you added an intercooler I'd keep a real close eye on it in warmer weather, I know 10psi is the limit for the L28ET without an intercooler but the stock ECU, top ring land and the cast pistons are all notoriously weak int he L28
winez31
its fall here now so its around 50 40 degreeish all the time
NSR240sxe
Car: '97 Kouki S14, '98 Sentra SE
is there such thing as too much boost?? lol
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
NSR240sxe wrote:is there such thing as too much boost?? lol
Only when the injectors, ECU, fuel pump, etc can't keep up.
Otherwise, your foot is the best boost controller around.
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
Z-Bum, what would be some good upgrade junkyard injectors for both the z31 low impedence and the high impedence injectors? I was just curious on what cars have those style injectors and what flow rates. Thanks,
DustinZ
winez31
try rx7s 550s
DustinZ
way off, Rx7 injectors are completely different than z31 injectors, Rx7 injectors are top fed direct by a fuel rail that bolts down to them, Z31 injectors are top fed by a hose to the fuel rail. Two different style injectors. Be carefull what you post because you might really throw someone off that might not know any better and might end up coming out of pocket or worse.
*****Z-bum,******** I know some early mercedes are the right top fed type and are 380cc, I don't know anything about domestic cars but I think Ford has some injectors that would interchange?
winez31
actually im using rx7 injectors right now. you just have to use a bigger fuel line and resitors.
AZ-ZBum
DustinZ
Z-Bum you are the best..... Thanks
DustinZ
Return to “300ZX (Z31) Forum”
