To MREV-2 or not to MREV-2
WESIDE
Car: 2006 g35 coupe
Thinking bout goin with this mod. Are there any reasonable gains here after the bolt ons that I already have. I was reading in the past that there was a signifigant difference with this mod when installing on a non rev up motor compared to a rev up motor. Any input? Wes
G_whizz
Car: 2010 G37 Coupe Sport
I say doeeeeet!!!
chad1200
Car: 2004 G35 AT Sedan
check this thread out.... http://forums.g35club.org/zerothread?id=228251
it's a long one.
from the research that i did some people didn't notice much and it's kind of pricey. save up and get a Stillen exhaust
i believe you have a revup engine so if you do go with the MREV2 than keep your spacer on.
let us know.
G_whizz
He already has an HKS exhaust.
At first I wasn't sure if I noticed a difference. After a couple days of hammering it...I did see a gain
Bobby23
Car: 2006 G35 6mt
you have an 06 so i'd say do it...i'd go with the 5/16 spacer and mrev...makes a pretty big difference...it also makes you car sound that much better...not sure you'll be able to hear it over you hks and test pipes though! lol
chad1200
oooops! home sick today. i need to read a little closer.
GO FOR IT!!!!
pae9132
Car: Modified 03 V35
does anyone know if the mrev will work on the 2003 automatic? it says you can send in your core plenum for a discount so I'm not sure if that means that it will work or not. I also already have a kinetix v+ plenum installed which is the top half of the plenum. Thanks.
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
Dumb question, but what does 'rev up' mean?
Bobby23
Car: 2006 G35 6mt
the rev's come with the 05's 06's and 07's...they have bigger cams so they rev higher and have 298 hp...
WESIDE
Car: 2006 g35 coupe
I will definately look a little closer into this mod. Thanks for the feedback. Wes
LMG_35C
3/8" Spacer, Copper ISO-Thermal kit and MREV lower plenum on my 2004 6MT coupe here.
Some have commented that they thought the MREV causes the non-revup motors to run lean. Although I haven't gotten an AF reading, I can't feel or hear any ping. I would be a bit more concerned if I had HF CATS and/or performance exhaust.
I added MREV a few months after spacer and could definately feel a difference with each add. Much stronger pull in the 3-5000 rpm range, especially 2 - 3rd gear. I only run Sunoco 93 to be safe.
