naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Thu Nov 10, 2005 9:18 am
It is too hard to tell from your picture how low the car is. My car is around a 3 finger gap between the fenders and the tires all around. I have Kts coilovers, butI do not have any adjustable links, except for the front pillowballs. Going to a race alignment shop is not neccesary. I go to NTB for my alignments. My rear wheels are at about 1.5 degrees of camber, and my fronts are at around 2. The pillowballs are at the 0 setting (I always have them set the lower mounts, and I mess with the uppers when I track the car). So.. to answer your question, I do not think that it is too low, but it might be. If you are lower than me, you may have to run slightly more rear camber, but other than that, everything else should adjust back to spec just fine at any alignment shop.
