To keep power steering..
Nameless EJ6
Car: What the **** do you think.
I haven't seen too much good information about keeping the power steering when swapping an RB into an s13/s14.
All I've seen is "you'll need custom lines"...
I don't own a 240, but I will very soon. So pardon my inability to look at the power steering rack myself.
What kind of custom lines? Are they solid lines that need to be done by a professional or could I use some custom lines similar to these?
I guess the one question I have.. is this a DIY job? :)
Redline240
Car: 95 240sx
Just so you know, the only issue with PS is when keeping the RB26 twin turbos...no problems with the RB25, RB20, and the RB26 with a single turbo upgrade...oh and i'd like to know more about it too...
Redline
opensource
nothing needs to be custom or changed. the stock lines bolt to the RB's pump. just have to re-arrange some of the lines.
Nameless EJ6
Thanks guys. Sweet.
opensource
yeah for the r33 member, you have to pull and bend to get them to form and fit onto the x-member. it was fairly easy, about 15 min.
DarkParadigm1
whats the difference between the different xmembers?
Nameless EJ6
NightXCZ77 wrote:Opensource is correct if you are using the KA x-member and custom mounts, but with the R33 x-member, you need to custom route the lines.
Night
KA X member and custom mounts? Can you explain the custom mounts more? Like custom mounts I would buy? Engine mounts? Teach me brotha.
Thanks.
By the way, Night, are you here in washington state? :)
raging panda
Car: s13 coupe
OK, i was all geared up to go the RB route, but now im not so sure. I kno it seems nieve, but I thought this was gonna be a bolt up affair, use the RB Xmember, RB motor mounts, shifter would be a little forward. Now I see that a little custom work may be involved and it may cost more than I had originally inteded. Please help, tell me what custom work or difficulties are involved with installing a RB engine.( not a 26 TT tho)
93RPS13
Car: Cars, Girls, Cars, Food
what line are needed to be rearranged opensource????
FiZ
Where does the A31 crossmember stand in all of this? I heard it's a "better fit" to use. Does that mean the shifter will be aligned better? PS lines wont need readjustment? or what?
Redline240
Car: 95 240sx
FiZ wrote:Where does the A31 crossmember stand in all of this? I heard it's a "better fit" to use. Does that mean the shifter will be aligned better? PS lines wont need readjustment? or what?
Using the A31 crossmember will allow your engine to sit lower, however the shifter will still be slightly forward...
Redline
wcbjr
Car: KA24E / hatch
Bump, for some HICAS information. What to do with the other port on the pump.
