To go, or not to go, synthetic
hnic514
Car: Silvia S13
My ca18det has 58 xxx km on it was wondering if i should switch to synthetic or just stick with mineral what do you guys think?
bone_stock_240
Car: 1995 Infiniti Q45
Since it is so low mileage, you may as well try switching, and watch closely to see if you get any leaks. If not, you are in the clear. If so, change back to dino juice.
hnic514
Car: Silvia S13
thats what i thought ill try it out and hope for no leaks but should i use 5w30 or 10w30?
Masterdebater
Car: 1989 nissan 240sx coupe
10w30 in summer and 5w in winter
hnic514
Car: Silvia S13
the s13 has never seen winter nor will it so 10w30 should be fine all summer till i store her again?
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
hnic514 wrote:the s13 has never seen winter nor will it so 10w30 should be fine all summer till i store her again?
Yup, doesnt it say in the owners manual what weight oil to use for what conditions?
Masterdebater
im running mobil 1 10w30 and seems spectacular. although 4 quartz and a filter came to be just under 50 bux lol. i say go for it. ur engine may like it
driftin8ez
Car: 92 Coupe, Turbo Miata
i don't know if it's different with synthetics but i never run anything lower than 40 weight on a turbo car. Even my friends 1.8t gti uses 0w-40 in the winter. I'm using 20w-50 in the summer and 10w-40 in the winter. Castrol GTX. She runs great on those combos.
boost_boy
I don't blame you, dude. I run 20w-50 year round. But then again, it's hot enough here for this as well. And as for synthetic, if you have the money to throw away, go for it. You can use Advance Auto brand oil and still keep a healthy engine. Just have to change the oil more frequently, but the costs is well and worth the labor. I personally run Castrol syntec blend in all my cars as well as other folks' cars and they're all pretty healthy still. Doesn't really matter what oil you use as long as you're wary of the weight vs the climate.
Dee
driftin8ez
ya i give my car hell and with a lesser weight oil it would be burned up in one trip to the parts store. LOL. I always change my oil and filter before an event and try and change it soon after as well. Most of the time i skip a filter change after an event if i change my oil seeing as it only had about 30 hard *** miles on it.
rico05
Car: 1992 RMS13 w/ CA18DET
I work for Advance Auto and even I wouldn't use that crap, lol. $2.18/qt? That scares me.
I have been running Mobil1 15w-50 since day one. 3 years of daily driving, track days, 7000+RPM shifts, and overboosting (18psi here and there) and no complaints. Even before my oil cooler I never had an issue. Great stuff.
DIng-KF
Car: Nissan CA18DET powered
Mine has about 100.000Km and i ve been using synthetic oil (Motul 300V) for the last 2 years which is about 15.000Km. At first i used 15W50 (summer and winter) but in the last oil change i used 10W40 and the car seems to like it better. I m about to change it again so i ll go for 10W40 again. I was worried about possible leaks but haven't noticed anything strange.
Changing to 10W40 from 15W50 i noticed a bit lower oil pressure at idle (about 2 bar = 29psi) but it is fine at higher rpms (about 3.8-4 bar =55.1-58psi at 3.000-3.500rpm most of the times).
rico05
I think I might switch to 10w-40 as well. My lifters are always really loud, and we started stocking Royal Purple at work, so I can use my discount.
Masterdebater
rotal pruple is the shizznit so i hear but money wise its expensive. if u can afford it and with a discount (woo!) id go with the royalo purple. rico did u rebuild ur ca to be pushing it that hard?
float_6969
PLEASE DON'T USE CAPS IN YOUR THREAD TITLE, IT'S REALLY ANNOYING.
(See how annoying that is?)
I prefere to keep the oil above an Xw30 if possible as well. I run 10w40 year round and don't seem to have any problems.
Zero260
Car: 91 240sx coupe
I'm going to use royal purple after I have the bearings broken in, it's only like .30 cents more than Mobil 1 so it's not like I'm dumping more cash into it.
Nowhere
Car: Suzuki x-90, samurai
Here's how to choose your WEIGHT of motor oil
Read the WHOOOOOOOOOOOOOOOOLE THING!
http://63.240.161.99/motoroil/index.html
get something to eat first and go to the bathroom, it's a long read :D
themadscientist
Mobil 1 15W50 for 10 years in the 180.
