.Q451990 wrote:Those clumps of sludge in the filter on that site scare me! Clumps are bad! Slow is good in this case...
Heath
Probably wouldn't be a bad idea to install an oil pressue gauge. At least you'd have some warning that your engine is about to seize instead of the idiot light which just tells you that your engine is toast.Q451990 wrote:Fresh conventional oil... add a half can... drain, repeat, drain... then fresh oil. That would be my first step. There's a lot more danger in flushing too agressively vs. not flushing at all. You don't want to loosen up too much stuff too fast and plug up the oil pick-up.
I have also heard good things about the Envirolution flush - so if this doesn't I'd try that next. If it's reasonably economical I might even skip the BG Quik Kleen and go straight to an Envirolution type flush...
Heath
