95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Mon Nov 12, 2007 9:09 pm
350$ sounds very fair (actually cheap) to do the rear main, it is a crutial part in the engine, and requires removing the transmission and drive shaft to get to it and replace it, it takes 5 minutes once the transmission is off, but it seems like he is charging you the labour for removing the transmission (which i think is fair)
the rear main seal wears out after a period of time, when it fails, it is totally random.....(except adding too much oil when changing the engine oil, and even that has to be done 10s of times for it to cause the rear main seal to fail)
i would also flush the transmission fluid since it is going to be taken out
and finally, i doubt that your mechanic had anything to do with it, unless he had some work done on the transmission
i hope this helps, please update
