hilux30 wrote:Need to tie the body together, it feels like the whole shell is taking a beeting and too much flex. I don't understand where this notion comes from that a cage or braces is going to make things worse, it's chassis rigidity not suspention siffness.
This flex is the chassis absorbing the bumps in the road. Yes, adding a cage will reduce chassis flex, but now instead of absorbing the bumps the chassis will translate the bumps to you, making a less comfortable ride.
If you drive the car on the street don't cage it, I guess that's the answer you are looking for.
