3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Apr 16, 2011 3:00 pm
preface: i have been using the m1-208 exclusively on both g50s for almost 50k mi. i also perform regular UOAs, and the worst insolubles i've had was a 0.3% on a 7100 mile run of 0w40 (blackstone flags 0.6% as being the threshold of 'bad'). and, anyone who knows me knows that there is no way i would ever knowingly let an oil filter get clogged. unfortunately, our friends at IoS no longer stock the M1filters [they also used to sell them at a very reasonable $6.50]. So, the part is not discontinued, and i'm tempted to not mess with success and just fork over the $11/ea or so not counting when advance has a 30% off coupon or something.
However, always being on a quest for something 'better' i've been poking around at other options and there are a few: the wix 51361 and pureone L24457 are direct replacements,including that there is NO bypass valve (like the m1-208). The stated flow rating for the 51361 is 7-9 gpm. However, there is at least one option with taller media and the same 3/4-16 thread, it also comes with a bypass valve set at 8-11 psid.
Question 0: how much does a stock vh45de oil pump displace at say 3000 rpm? 6000? is it likely the same due to pump 'relief' valve opening?
Question 1: (i suppose only Brian, qship96, and Daedalus have a 15208-60u00)--does the factory filter also have NO bypass?
Question 2: assuming yes (NO bypass) on the -60u00, then we presume the vh45 designers wished to have always filtered oil, possibly at the expense of pressure. note however, that the vh41 -9e000 filter DOES have an 8-11 psid bypass. So, debate: better to have a fail-safe bypass in the unlikely event that the media clogs--delivering un filtered oil to engine, or better to lose oil pressure and get the idiot lite warning of imminent danger?
