added some oil into forth compression wentt up to 140psi with 200k i figure not only the head gasket is murdered but also my piston rings.The question is should i redo my head gasket and hopefully it will stop pilling smoke out of my muffler also will bring up compression up a bit so i can drive for another 3-5 month untill i get my sr20der swap.I just wannna be sure the car wont die on me and it doesn't look like there is bbq inside.
