to anyone that used the frsport wiring guide
ZootedS13
Car: 1990 240sx se
im using the fr sport wiring guide.
http://www.frsport.com/SR20DET....html
i had the ka plugs they say to use on the last step so im soldering them all together and i found a problem. theres no match for the brown wire ( O2 power)
i read the update on the bottom but i dont think i should solder it to the main ignition.
anyone else do this? if so what wire did you solder it to on the ka plug? ac?
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
IM using it right now. You talking about the 3 plugs that have to be swapped correct? Mine doesnt have the black with pink stripe for some reason.
ZootedS13
Car: 1990 240sx se
yea the 3 plugs that connect to the body harness.
first off im VERY colorblind so i had to get my step dad to tell me what wires were black with red stripe and what ones were black with pink but i got them all now......except the brown...
the ac wires might be a possibility but im not sure.
just need this wire and fluids and ill start up my car for the first time
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Thats the way to do it. Mines been like that for 2 years no issues with the o2 system. Don't rethink the ARK man..
ZootedS13
Car: 1990 240sx se
whats the way to do it? lol
if you mean the a/c wire then witch one?
blue/green stripe or green/yellow stripe?
and what does this mean?
240life wrote: Don't rethink the ARK man..
240life
connect the brown wire directly to the red/black wire like they tell you to. Read that whole guide and then repeat the steps, almost every thing is 100% correct...the only difference I had was on the fuel pump wire. my engine harness side was purple/black tracer instead of pink/black tracer
ZootedS13
Car: 1990 240sx se
to the main ignition wires? hmmmm sounds risky
and i would go about this by just soldering the two black/red stripe ignition wires together with the brown one so all three are soldered together in one spot?
sorry for second guessing you so much i just dont want anything bad to happen this close to start up
240life
Yup, your ignition will only see battery voltage when the key is on so your o2 sensor only sees voltage at that time too.
ZootedS13
Car: 1990 240sx se
thanks for all the help.
