deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed Oct 19, 2005 5:45 pm
Timing will never be after TDC, that would be known as truly "retarded" timing (sparking after piston is at TDC). Timing is generally always above 15 degrees BTDC, for the sake of discussion. As Rpm increases timing before TDC will increase (more timing advance), as load or "boost" (airflow) increases, timing will generally decrease from where it is at a lower airflow.
When you hear people say retard your timing, they mean retard it from its current timing advance btdc. It will never go truly after TDC, sparking as the piston travels away from TDC. If it does, your fuel will be likely to ignite in the exhaust.
Now, to further explain the timing map a little bit, here is a picture.
Blue circle near the bottom indicates where the ecu is reading from during idle (general low rpm, low airflow). You will see on the left of the picture there is a scale of RPM, from high rpm to low rpm. As rpm increases timing advance increases.
Now, up on top you see the arrow and increased airflow. As airflow increases, timing decreases. So, if you were at full RPM and full boost (or airflow) the ecu would be reading at the top right hand portion of the map. If you were at low rpm and high boost (for sake of discussion), the ecu would be reading from the lower right hand portion of the map.
I know that over on eccs.hybridka.com the information is scattered around pretty bad, and is not the best for a beginner. The forum is rather fresh, hopefully in time there will be a "team" to help organize and make it easier for beginners. We are having some issues with the forum getting moderators set up. That will be a start to getting everything organized.
