the 2 wires you cut were grey right?, and it looks to me that your using a 300sx ignitor. if so those wire are useless.sean8564 wrote:Ok so i have no Spark and my ECU says 55All Lights come on but will not crank I cut 2 of the un used wires by the ignitor and soderd the 2 wires together that we hook up with a connecting spade
could come get the car? If that's what you meant then good. Yeah, they do stay pretty busy over there.sean8564 wrote:i called today and theyt said they were busy and could on get the car and get to it next week on tuesday.
The swap looks fine to me, except for the wiring, which the OP said Tophat didn't do.turbodcivic wrote:that swap looks horrible, i would NEVER have taken my car there do have a ****ty job like that done. ok first of all , your gonna have alot of plugs left over that your not gonna use. just look at the write up on http://www.FRsport.com and look at which plugs arent used. and goodluck. i m too lazy to type. ive been doing sr swaps all week.
Bogus.sean8564 wrote: PLus I have to bring them the car they will not come
Pluged those two together yesterday the two hoses were loose Now the car still breaks up and sputters like it is firing on empty cyliners so i do think it is the cas that needs to be adjusted I just hope i have not craked a pistion while drivng it till i can get it to them cause For 1700 Dollars i woul have thought it would run perfectaucerumo wrote:check ur intercooler for leak. if u have side mount intercooler check where u cap off the original bov. friend of mine has same problem. car wont rev over 4k, turbo spools but no boost, sputter and smell gas all over the places.
where on frsport is this write-up? i don see it : \turbodcivic wrote:that swap looks horrible, i would NEVER have taken my car there do have a ****ty job like that done. ok first of all , your gonna have alot of plugs left over that your not gonna use. just look at the write up on http://www.FRsport.com and look at which plugs arent used. and goodluck. i m too lazy to type. ive been doing sr swaps all week.
Google owns you http://www.frsport.com/SR20DET....htmlTouge’ wrote:where on frsport is this write-up? i don see it : \
You and me both.sean8564 wrote:....cause For 1700 Dollars i woul have thought it would run perfect
