To all you rb pro's out there!
marcus8789
Car: 95 NISSAN 240SX
I finally finished up putting in my rb25det in my s13!!! All the wiring is hooked up, fluids, hoses etc..... when it came time to hook up the battery I did,........and the starter was making this weird noise without anyone even turning the key . The starter is not cranking, its just making a weird noise and the solenoid gets really hot! When I go into the car it doesnt do anything, no crank, nothing! If it is the starter thats f**ked up, do u guys know a replacement part number at my local All Parts store I could use? Anything, any ideas? Help
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
most likely the wiring, or a signal wire wire shorted with out the solinode engaging, whatever no time at work to think about it.
But if you need it rebuilt I can have it done.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I had my starter re-built at my local battery store.
Take your starter off put it in a vice and test it on the bench. That will let you know if its the actual starter or a wiring problem.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
rb25drag wrote:Take your starter off put it in a vice and test it on the bench. That will let you know if its the actual starter or a wiring problem.
+1
Just when forums were getting on my nerves again... I see this... perfect logic
