To all with S.tech and Agx's
240sxHitman
Car: Boosted '91 240sx
I have tein s. tech springs and agx struts but not installed yet and i was wonder the rubber part thats on the bottom of the spring will it settle in properly after install? or do i have to do sum modification to that rubber on the bottom of the spring
Hijacker
Car: '92 240sx Convertible
'94 F-150
just install it the same way the stock springs come off and you'll be fine.
Chingon
Car: 1991 and 1992 hatchbacks
or better yet, like the manual says.
kamikazestorm420
rubber thing on the springs??
it should be on top
popogto
ok, with the shocks and spring off, put the spring on the shock, turn the spring around untill its straight up and down. thats where u want it to sit. and the rubber thing stays
ralphdig
Car: S13 240SX SE - FiatSchumacher- Peugeot 307XR- Renault Alpine A110
240sxHitman wrote:I have tein s. tech springs and agx struts but not installed yet and i was wonder the rubber part thats on the bottom of the spring will it settle in properly after install? or do i have to do sum modification to that rubber on the bottom of the spring
Maybe this helps
