ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Mon Jan 24, 2005 9:46 pm
You can always try starting without the MAF plugged in to put it into safe mode to eliminate one problem. Another is, pull off the fuel rail and have someone try to start the car. Point the injectors up into the air away from your face and pull all the plugs to make it easier on the starting RPM. Watch the injectors fire starting with #1. It should fire 1, 3, 4, 2. All should have the same looking stream of fuel. If so, move on to the coil packs. I've seen dead ones before, so plug them into one know good coil wire and put a plug in it. Place the tip of the plug against the firewall or the exhaust manifold and have someone start it (again without sparkplugs bolted in). It should show a 2-3 sparks per second. Check all coils by placing them on the last known working coil driver. If all checkout, begin placing working coils on each coil connector driver and see if they all have a spark. My cousin had a problem where coil driver #1 was trying to substitute by firing for all 4 (meaning #1 will fire a spark 4x as fast). #2, 3, and 4 never fired. This is with a 61 ECU. I gave him my 62 ECU and all went well, so I let him have it since I use a Haltech now. The main thing is checking for fuel and spark in the correct order and making sure everything gets fuel and spark to begin with. If all checkout well, check CAS timing carefully, then move on to cam timing. To time the cams correctly without using mating marks, set to TDC, set exhaust cam KEY to about 12 o' clock in reference to a leaning motor (leaning to the driver side a little). From there pull all slack out of driver side of chain and slip over the exhaust cam sprocket. Then count EXACTLY 20 chain rollers in between the mating marks of both cams before bolting down the intake cam and sprocket. The "blind" trick I've used for all SR's I've worked with has never failed me even once.
