To all those who have installed the Z tube pop charger...
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Be sure to check that the hose clamp where the Z tube ends and the MAF connects. There is a rubber flex tube there. I reused the hose clamp that was stock.
The problem is, that the hose clamp has rubbed a gash in the side of the tubing on the high pressure side of the AC tubing. It hasn't burst yet, but I would guess it's about 75% of the way through the wall of the tubing.
I spoke with my buddy at Nissan. He said the part isn't cheap, and it would be 3+ hours of labor.
It's something I will do myself, but it looks like a suckfest.
Just wanted to give you guys a heads up.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
wow that sucks!
On my Hemi Ram my intake tubing touched the AC hose my fix was to wrap the AC hose in foam and then electrical tape. When the tubing rubbed through the tape I'd just add more?
I think the Fujita misses everything else
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
I have my clamp turned enough where there is no contact.
Beancooker
Yep, I turned my clamp to the side also.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
i heard about this causing a lot of problems for people...I double check mine from time to time to make sure there is no contact
Good heads up
Focusedintntions
Car: 07 Infiniti G35 Coupe 6mt
Pic by chance? I'm going to do this mod soon and would like to know what to keep a heads for it.
Beancooker
Yeah, I'll post up pics this afternoon. I'm at work right now, so it'll be after I get home.
G_whizz
Car: 2010 G37 Coupe Sport
Focusedintntions wrote: Pic by chance? I'm going to do this mod soon and would like to know what to keep a heads for it.
Uunngghh... this will seriously suck...I'll check mine at lunch.
Beancooker
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Beancooker wrote:Be sure to check that the hose clamp where the Z tube ends and the MAF connects. There is a rubber flex tube there. I reused the hose clamp that was stock.
That's a crappy oversight.
The line is a few hundred bucks and not an easy DIY. I have replaced a few of these and it requires Recover and Vacuum/Recharge equipment, and more patience than I know you have the lines are very malleable and irreparably bend very easily. That line runs from the compressor over the frame rail and behind the cowl to the evaporator. It also requires special tools to safely disconnect the AC lines.
I would rate this one at a 4 out of 5 if I were writing an article on this.
Ten cents of foam could have saved you from this problem, live and learn I guess...
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
Im going to go check mine!
DJ
tollboothwilley
Maybe you can put some JB weld in that area? keep it from becoming a hole. then wrap in foam or something.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
tollboothwilley wrote:Maybe you can put some JB weld in that area? keep it from becoming a hole. then wrap in foam or something.
That's not going to keep the line from rupturing. It may work as a temporary fix but that will not improve the overall integrity of the line. Depending on heat load and operating conditions the AC lines can hold some serious pressures. Average on the high side (the effected line) runs ~120psi while operating, depending on heat and humidity.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Nice Heads Up Beaner!!! Checked the coupe will check the sedan in the AM..
Beancooker
SteveTheTech wrote:Ten cents of foam could have saved you from this problem, live and learn I guess...
Next time, just throw acid in the wounds instead of salt.
SVTCOBRA wrote:Nice Heads Up Beaner!!!
I just don't want to see anyone else suffer the same problem I am having.
Tampa G35 Sedan 6MT
Steve that was a MR.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I'm just messing with you, the joy on the internet is the lack of sarcasm.
~Noah You really shouldn't have much of a problem (hopefully) if you leave the line alone. Don't touch it don't move it just leave it alone. If you bring it to me I'll fix it for you.
