crackler »
https://forums.nicoclub.com/crackler-u26495.html
Thu Jun 26, 2008 6:15 pm
RS*R makes springs. If I had to guess, straight rate springs at that, not the "progressive" springs.Also Eibach, and Hypercoil make good springs. Find a local reputable race shop (not some tuner shop, find out where your autox / road racer friends go) they should be able to help source your shocks and springs as well as possible recommend rates. I don't know what rates are usually run on the 240. but their are a lot of factors that go into choosing spring rates.
With the ground control, you can basically run any spring rates you want, assuming that they are made in the size you need, and won't destroy your shocks. You will need to find out what the max spring rate is for for what ever shock you get. Also know that the Koni's have to be removed and the springs have to be pulled to adjust the rears. The front's use that cool little knob.
BTW, I run Koni Yellows and G/C sleeves with Eibach springs and LOVE my set up.
Just Google Koni NA or Koni North America.
The Konis are going to run you about $600, plus probably another 250 - 300 for the springs as well. And another 450 (I think) for the Ground Control sleeves.
