Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Sep 25, 2008 4:17 pm
The plastic housings will hold at least 25psi.
If you truly think it is a MAF issue, get an Apexi intake filter. Mine is connected directly to the MAF and I dont have any problems. From the looks of that filter, there is no "horn" on the interior of the filter to smooth the intake stream once it passes thru the filter element.
As far as being too close to the turbo, I doubt that too but it is a possibility. Check out my engine pic on the pic thread. My intake goes Apexi intake filter>MAF>90 reducer elbow>4" turbo inlet. That is about as close as one can physically get.
What makes you so sure it is a MAF problem and not the IACV?
Also, shouldn't the turbo center section have the oil feed and drain in a vertical orientation not at 5 and 11?
