Well, assuming you are running a stock tire diameter of 24.6" and the stock rear end ratio of 4.08...slamdbusa wrote:What is your tach reading at 70mph? I would like to know, if the gearing is wrong or a six speed is needed.
VH45 and Z32 gearbox s13. Is the RPM's high like 4k or something or around 3k?
I am using the stock diff. So the RPM's should be at 3k, that means my tach is way off. What is the ratio on the 300zx and Q45 diffs?elwesso wrote:are you still using the stock 4.08 diff?
Yes this thing just pulls like crazy. I am running an open diff right now, and last night I wanted to see if the one wheeler peeler would happen, and to my surprise both of the tires lit up.T45 wrote:Ouch, I may have to re-consider using the Q diff in my Z.
I bet your 240 gets off the line quite nicely now though!
I think the best way we can double check tach signal is to either use a high end timing light with an LED RPM readout or hook up to the consult system.slamdbusa wrote:I saw that post, I already did that, but I have no way of making sure if it is dead on.
I don't know because of when I get on it, the RPM's go up to and past the 8k on the stock KA tach. but at Idle, it sits around 900ish. I assume that this is close to it but not dead on, that is why I would like to know what the others have for theirs at 70mph.
I liked all the gearing specs, so that tells me that the engine just sounds like it is at 4k at 70. I'm just not used to it I guess, lol.
On another note what exhausts are you guys running? True duals with an X or H pipe, what size, does it need to follow the setup for the Cobra's exhausts?
I don't have one of those timing lights, and I would have to pull out the wire diagrams again to find the Consult wires, lol.tmorgan4 wrote:
I give it a shot, I was thinking on using a GReddy turbo timer from the last set up, but I forgot that you still have to program the RPM's, D'oh.T45 wrote:There is another way with a multimeter if I can remember. I think you measure the tach wire with the meter in AC voltage mode and put red on tach and black to ground and it should tell you what the rpm's are.
Stock Z NA = 4.08Stock Z TT = 3.69Stock Q45 90-96 = 3.54Stock Q45 97-01 = 3.69slamdbusa wrote:I am using the stock diff. So the RPM's should be at 3k, that means my tach is way off. What is the ratio on the 300zx and Q45 diffs?
They'll both light up in a straight line, for a little while anyway. Try punching it going round a turn and the inside tire will go up in smoke...slamdbusa wrote:Yes this thing just pulls like crazy. I am running an open diff right now, and last night I wanted to see if the one wheeler peeler would happen, and to my surprise both of the tires lit up.
Yes they will, lol. I have a welded diff waiting to go into it.SuperHatch wrote:They'll both light up in a straight line, for a little while anyway. Try punching it going round a turn and the inside tire will go up in smoke...
