qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Wed Feb 23, 2005 10:53 am
the overall diameter should not have significantly changed,you have taller wheels,but shorter tires. the alignment numbers should not be affected at all by the new tires-the only alignment spec that can be adjusted on the q is toe in/out,which changing tires should not affect at all.now,if the alignment was off before the tire change,it will still be off! worth a check to preserve your new investment,imho!
