By the way TnT Garage stands for The noisy tribe which is the translation of bosozoku...Im sure most of you know this but this is for those who dont.
Heres the current status of the build.
Motor: Series 2 Rb25det
Current parts list
Engine:
cryogenically treated crank,pistons/new rings , and rods
acl race main and rod bearings
arp main, head, rod bolts
Nismo N1 oil pump jun crank collar
nismo n1 water pump
200zr pan from my original rb20
oem timing pulley and idler
greddy timing belt and jyg cam gears
cosworth 1.5mm head gasket
More to come......
Spec stage 3+ clutch and 12lb flywheel
custom driveshaft
Turbo setup
Borg Warner s360 with Stainless .63 t3 hot-side
Exotic Speed rb25det manifold
Precision Turbo 39mm wastegate
custom v-mount intercooler 2.5" piping
Fuel
Jyg Top Feed Fuel rail
Sard 550cc top feed injectors and Fuel pressure regulator
aeromotive 340lph Stealth fuel pump
Nistune..will be dyno tuned when motor is done
Wheels
Compomotive ps16 3 piece forged racing wheel 17lb each
front 16x10 5 1/2" lip unsure offset
rear 16x10 6 3/4" lip unsure offset
So before you ask why it has a red hood. Here is what happens to your 200zr hood when it goes flying off on the highway. I moved last year and the tow truck guy came to move the car when I wasn't home. I had told him to strap the hood down.....you can see he did a good job of that.
I just bought these wheels and they didn't get to me yet so this is best pictures of them.
