tloof, I have a couple questions...
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
garyweinrib
I noticed that the old MSN 720 forum has been removed. This is extremely unfortunate, considering there was a wealth of information on it! Are there any newer posts here on the NICO forum that will cover the information needed for the 720 NAPS to KA swap? Now that I might finally be in the position to tackle this, the outrageous amounts of information I was going to rely on seem to be gone! Here's my situation:
85 720 2WD short wheelbase
I'm looking to go the simplest route, with just an KA24e from a hardbody.
From what I understand, the tank and the fuel pump can be used from a Z24i, which I have access to.
I will be capable of tackling any minor mount issues.
But, CPUs, harnesses, and the like? What exactly do I need? Will the stock 5 speed mount right up?
I know you've answered these questions several thousand times over, so where I could I find the info, if it exists anymore?
PEZi
from what you've given... all you need to know basically is that you need the transmission out of the hardbody as well... a different driveshaft if they don't happen to be the same length.... and the ECU and harness will need to be the hardbody's...
lil89ram50
Car: 1985 nissan 720 1989 dodge d50 1979 chevy luv
ummm pretty sure you are wrong here pez... the ka bolts up to standard 5 sp 720's..... right? if you go to the "how to" section at ratsun.net, there is a stikied thread that is called how to swap ka, sr..... into anything, lots of great info there! wish we could get that coppied and brought to here, but not sure how to, w/o re wrighting all it myself
please correct me of i am wrong pezi
PEZi
hmm... i think it may be in the bellhousing then... cause i'm pretty sure the transmission is not completely direct bolt up... a bellhousing swap isn't bad tho
lil89ram50
well hopefully i can tell you for sure tomorrow as i am also doing the swap, and will hopefuly have a cherry picker tomorrow to pull out the old, and fit the new
lil89ram50
well i am behind schedule, with work the gf and no cherry picker, i jus now got the transmission out! it does bolt directly up to ka24de...not sure about the ka24e tho.... but would think it has same as the de version.....
Return to “Datsun 720”
