Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Mon Jul 09, 2007 1:35 pm
Pro-Comp, Rancho and FabTech all make various types of lift kits for the Titan that range from 2" all the way up to 6" for both the 2WD and 4x4 platforms.
You can also try a cold air intake system. Other items like blowers are real performance enhancers but they are expensive. Headers and larger diameter exhaust pipes will give you decent power gains and improve your torque curves at different RPM's. If you want any trail usability out of your 2WD pickup..
I would go for a 2" suspsension lift first.
Then upgrade to a tire size and moderately aggressive tread that is 1 or 2 sizes up from what you have now. This will give you a bit more ground clearance, when combined with the suspension lift, and give you better traction in the dirt without sacrificing too much of the highway comfort and quiet ride you currently enjoy. DO EXPECT YOUR FUEL ECONOMY TO BE REDUCED BY 1 OR MORE MPG DUE TO THE INCREASED WIND RESISTANCE AND LARGER TIRES.
Then a Cold Air Intake and Exhaust system from the Catalytics back to the tail pipe. These will free up some power and you may balance out your fuel usage and your available power output.
Unfortunatley in order to make gains in power and ground clearance you will ultimately sacrifice some of the fuel efficiency of your truck.
