wchai »
https://forums.nicoclub.com/wchai-u7628.html
Thu Aug 25, 2005 9:19 pm
Thanks very much Nistech. Only the top hose clamp on the return coolant hose came off. Overflow hose was fine. Dealer said the clamp was never put on right because the spring clip is still on (I didn't understand that because dealer took the clamp and never showed it to me). It is amazing that I didn't have any coolant leak for 9 months and 5000 miles.
My Titan drives fine for now. Sound/power/idle all appears normal. I just changed oil and filter (Mobil 1 synthetic, always). The coolant level is now at the min mark, and I hope this is due to air displacement in the engine, not leaks. Truck has a strong burned coolant smell so it reminds me everytime I walk by. The engine compartment is a mess, as you can expect. I tried to clean up a little but found it to be very difficult. I will try it again on Sunday. I think Nissan should've steam cleaned the engine compartment for me.
I will change the cheap clamp from dealer to a t-bolt clamp. Will also check all other hose clamps, just to be sure.
Wilson
