evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Aug 14, 2009 6:06 pm
the stock radiator might actually work out, but if the inlet/outlets are int eh wrong location a 22" GM radiator is popular for domestic V8 swaps
as for fuel pump your 73 should have used a mechanical pump, watever pump you use it will have to be external and to feed an engine that size you'll likely want a 75 280z gas tank which has a larger feed line and already has a return line
I like the MSD pumpmyself, and it's bargain priced
