palmerwmd wrote:Yesterday I did 7 quarter mile runs on the track.(with the weather being what it was, my et's were a somewhat disapointing 15.1 almost every time, but my trap speeds were a respectable mid nineties w/ the best being 96mph)I warmed up my tires with the ususal brake stand technique in "the pit", to warm up my tires on this cold day.
15.1 is very respectable, although 14s would be easy with a little better 60' time with 96 mph. A .1 improvement on the 60' translates to .15 to .175 in e.t. As an example, I got a 15.05 with 93.x mph and a 2.4 60'.
Quote »the first couple of runs were w/o brake stands but i didnt hook up at all getting 60 foot times of 2.6 and worse.
.[/quote]
I don't feel so bad about my 2.4 now.
I only got two passes when I went with my 93, and tried just flooring it on one, and brake standing on the other. I got way too much wheelspin on the brakestand, and got something like a 2.6 too. I think the best method would be a mild brake stand. You want just enough wheelspin to get the rpms up, but not so much that you just sit there and spin. I'm not sure if shifting manually or letting the auto do it's thing would be faster. My car shifts a lot harder on the 1-2 shift if it's done manually, but it "pauses" longer before making the shift.
Quote »But after watching everyone warm up their tires like that I did it too.
It looked really cool seeing those clouds of smoke coming from my wheel wells again and agin.[/quote]
Burnouts don't help with street tires. If you collect debris on the way up to the start line, you should spin them to knock the stuff off, but heating them up doesn't improve grip like it does with drag radials or slicks. If you get them very hot, grip will actually get worse rather than better.
However, if the track isn't prepped well, you aren't going to get good 60' times no matter what you do. Street tires just don't hook up well on a poorly prepped launch pad, and are especially bad if temperatures are cool. My other car picked up .75 in e.t. with no other mods than drag radials because it spun so badly through first and second gear on street tires.
I'd try my drag radials from my other car out on my Q45 the next time I go, but I have a feeling 9.5" wide wheels with 315-35-17 tires aren't going to fit.
