Michael Dennison wrote:I have just removed my Blizzaks from my '95Q and replaced them with my well worn Michelin Pilots because I couldn't decide what to do about new wheels/tires. I have successfully driven myself crazy and decided I needed some more time to decide. Here is my dilemma that hopefully you all can help with.
#1 - stick with OE 15" wheels and go with some of your recent suggestions (Pilot XGT's, Firestone Firehawks, Kumho's). By the way, what is the width of these wheels? 7"? 6.5"?
The stock wheels are 6.5" wide. The problem with staying with 15" wheels is that they are an "obsolete" size, and availability of good 15" tires is getting worse and worse. Most new "performance" tires don't come with 15" sizes.
Quote »#2 - buy new wheels/tires, but what size? 17"? 18"? 7" or 8" wide?? Also, if so, I guess forged is the way to go. Any suggestions on wheelmakers to consider? avoid?[/quote]
Another option is to get 16 or 17" wheels from a second generation Q. I got a set of 16 x 7" wheels from a 98ish Q, and am very happy with them. They are much better looking than any of the first generation Q wheels IMO, but are OEM quality and hubcentric, which many aftermarket wheels aren't. You can pick them up fairly cheap on ebay too. I got a set of cosmetically nearly perfect wheels for $300 I really wanted a set of the five spoke 17" touring wheels, but they are pretty rare. I only saw one set on ebay in months of looking, and they were very expensive (like $900-1000 I think)
Quote »Clearly I need new rubber but I also have other goals - looks and better handling. I've always wanted a tighter ride without being too harsh - especially on those long, sweeping bends when, at high speed, you you hit a dip and I feel like I'm wallowing.[/quote]
I really like the change on my car going from a 215-65-15 to a 225-55-16. The rear end used to wiggle around under the conditions you mention as well as on the highway at high speed, and that's gone with the new wheels/tires, but I'm not sure if that's due to the tire or the tire size. I'd guess it's the tires since my previous 93 didn't have the same feeling with 15" wheels/tires.
