Tires?
kc4x4
Car: nissan frontier
Can i fit a set of 31x11.5 tires on my stock xe v6 4x4 frontier and i also need to know the bolt pattern for it.
hannibal
Car: Red Line to Glenmont
Bolt pattern is 6x139.7 (6x5.5"), same as 6 lug Chevys.
EDIT: Ive found other sites saying its 6x114.3 (6x4.5") including a page from Courtesy Nissan. I'll let Chet or someone else handle this one...
In the size 31x11.5, is 31 the overall height and 11.5 the width??
kc4x4
IWannaS15 wrote:Bolt pattern is 6x139.7 (6x5.5"), same as 6 lug Chevys.
I know what size it is i just want to know if it will fit.
Exar-Kun
Car: 2005 350Z
I tried fitting them on an Xterra SE at my work, I had to trim the splash gaurds and lower fender trim to get it to fit... that was with the -larger-treadblock-than-normal BFG AT KO.
-Chet
kc4x4
Exar-Kun wrote:I tried fitting them on an Xterra SE at my work, I had to trim the splash gaurds and lower fender trim to get it to fit... that was with the -larger-treadblock-than-normal BFG AT KO.
-Chet
Would you be able to post me a pic?
Exar-Kun
Car: 2005 350Z
unfortunately no. That was 2 years ago when i worked at NTB...
sorry:/-Chet
