TIRES please read
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
ironmike77
Car: 08 Versa HB SL
oppinions on 17 or 18 in, and i want to get some new wheels too i found a few sites on google but they werent too helpful, anyone got any cool sites? i just got a 08 hb sl and im feening to put new tires and wheels on it
bigdog
Car: 2007 Nissan Versa S
2007 Nissan Xterra
1982 Dodge truck
try tirerack.com or discounttire.com
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
if you do alot of driving I would recommend 17's......
blindsnyper
Car: 2007 versa
17s
t19uz
18" !!!!
blindsnyper
Car: 2007 versa
19s!
Gr8dave37
Car: 2008 Blue Onyx Versa S
I can speak from experience...I have 18's and the normal everyday ride is rough. Knowing what I know now I would recommend 17's with a bigger tire, your ride will be nicer than with the 18's
t19uz
Gr8dave37 wrote:I can speak from experience...I have 18's and the normal everyday ride is rough. Knowing what I know now I would recommend 17's with a bigger tire, your ride will be nicer than with the 18's
Tup, better look 18" ---- better ride 17"....
STUPID RIDE 19" & 20" <---- uhauhauhauha.... ZERO COMFORT!!
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
t19uz wrote:
Tup, better look 18" !
Speak for yourself. When you get wheels THAT big, your tires don't even look like rubber bands anymore. They look like you just stretched a condom over a ridiculously large wheel.
17" would be the biggest I'd go. And even at that, the ride is a little harsh for my tastes. but they didn't make my wheel in a 16", so there you go.
Kelscar
Car: 2007 Nissan Versa Hatchback SL Magnetic Gray
2014 Nissan Murano SL Platinum Graphite
I really enjoy seeing all the modifications people are doing to their cars, but I have a question. And it may be a silly question but does changing tire size affect the speedometer readout? I understand that it is posible to go to a larger wheel size without changing overall diameter of the tire, but it looks like the od is larger on some of the pics I'm seeing.
bulld0g
Kelscar wrote:I really enjoy seeing all the modifications people are doing to their cars, but I have a question. And it may be a silly question but does changing tire size affect the speedometer readout? I understand that it is posible to go to a larger wheel size without changing overall diameter of the tire, but it looks like the od is larger on some of the pics I'm seeing.
that is where proper plus sizing comes in.....you need to match th overall diameter as close as posible
Kelscar
Thanks bulld0g.
ironmike77
Car: 08 Versa HB SL
whats the wheel width and diameter on my v i found 17s i wanna throw on their i just hope they fit
t19uz
bulld0g wrote:that is where proper plus sizing comes in.....you need to match th overall diameter as close as posible
agrreee with u bro !
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There are useful tools to help with that, too:http://miatanet.com/garage/tirecalc.html
Versa Blues
Car: 2007 Versa SL
Nobody is considering what larger diameter tires do to acceleration and MPG. I have 18's with 40 series tires. Appearance is "awesome". Compared to a coworker's stock Versa, there is a noticable difference in overall diameter of the tires. Larger rubber is like changing your gears in the rear end (on an older Camaro, etc.). You SHOULD gain MPG, but lose some acceleration!!!! Now for the "badder" news. You DON'T gain on MPG either. Because the bigger tires "work" the engine a little harder at cruise speeds, the computer compensates with a richer mixture. One thing I will say...my Versa with the 40 series Kuhmos handles significantly better than my buddy's stock set-up. My buggy came from the dealer with the 18's. If I was doing it myself (with what I know now), I'd go for the 17's w/ 40 series. This will load the engine closer to design and leave you with a little more "wheel well" if you ever decide to drop in lowering springs.
Return to “Versa Technical Discussions”
