Tires _ I30T
slayer
Car: Music, Movies
I bought a used I30T recently and I would like to know what would be a good choice of tires. I read a lot on Yoko's where the main complain was noise.
Any ideas on tires that would make the side smoother and quiter???? I would like a smoother ride with good traction in Winter.
Help please....
Mayhem_J30
Car: Ummm...My Car
michelon pilots all season touring
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
What size tires?
I've had two different Yokohama tires and found both to be very quiet, esp. AVS dB all season.
Are you willing to swap tires from summer to winter? Or need something to use year round?
slayer
Car: Music, Movies
All year....
Mayhem_J30
Car: Ummm...My Car
http://www.tirerack.com/tires/...5XGT4
not the same size, but these are what i'm running and i like em a lot. if you are on stock tires, which is what this is priced for, it's a good deal $89.
Q45tech
Generally the factory load rating on cars is just enough for the average owner.Find a suitable size [loaded rolling diameter]with a greater than [>5% or more] oem load rating will significantly improve tire life and improve handing roughly 1/3 of the % increase] since the tire slip angles are reduced!
Be careful of short term noise test as many directional designs get very noisey after the first 8-10,000 miles the Michelin Pilot H4 produces consistant low noise throughout its tread life [30-40k depending on application [rated load vs actual load]!
Jim Sottosanti
Car: Guitar collector..Martin and Taylor acoustics, Fender and Gibson Electrics
slayer...listen to mayhem....Michelin XGTH4's Pilots....there are 7 J's in my town and I've convinced all to switch...I'm sure they'd be great for your I30 too.
Love my Yoko's - Quieter than the BFG's it had.
