tires... how wide???
turtle
how wide can i go wit stock rims??? cuz i mounted 205 on right now.. and i want to know how wide i can go.. give me a size.. like 205? 215? thanx
base9se
Car: '95 240sx
I got a '95 240 and I would stick to 215 . I went to 225 before and the front rubbed messing up my wheel bearings. But you the rear should be fine with 225, I think it can handle 235 (not sure though).
turtle
how thin?
base9se
Car: '95 240sx
Currently I am running 215/55, it was 225/50.
Exar-Kun
Car: 2005 350Z
if you have an s14 a 205-55-16 is the best fitment for the thin 6.5" wide wheels...
an S-12 can use a 205-5515 on the stock 6" wheel, and it works nicely, and there's more sticky tires available.
the problem with 225-50-16 is that they're too wide forthe rim, its not an unsafe fitment..just not "good" IMO since the bead gets pinched...
-Chet
sr20detspec
how about 225/55/16 for the rear?
SmithSR
Car: 240sx
taller, so there's more sidewall to allow for bead pinch effect, but still too wide for the stock rollers!
