adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Mon Feb 05, 2007 7:45 am
like if your wheels have a really low offset, for example +0, and your tire width is 235, your tires are gonna rub on you fenders (assuming your car is low enough for your tires to touch your fenders). but even if you car isnt lowered, when your spring and shocks depress due to like a bump in the road or through g force by sway, your tires will rub (with the assumption of a +0 offset).
you dont want your tires to rub, especially if your fenders havent been rolled, cuz if it hasnt been rolled, the inside of the fenders are usually sharp, leading to your tires being grinded down by your fenders.
here read this. good info. i doubt you'll have to do the fender pull, but a fender roll is definitly recommend to all, esp with those that have lowered cars w/ lowered offsets.
