fueler wrote:ohhh QX4 rims sorry i was thinking of the 3 spoke pathfinder rims ya those tires u mentioned will fit. the only difference is the tread pattern will be a little bit wider (goin from 245 to 265) but all other dimensions will remain the same.
You are half right. Yes, the tread will be wider, but keeping the same aspect ratio (65), these tires will be a bit taller too. The 265s will be about 3/4" taller overall
265 x 65% = sidewall height...but this can be misleading because every tire is made different and sometimes, the tread will extend on to the side of the tire. Sidewall starts where the tread stops.
