tires for drifting
Nissan dominates the drift scene - Always has, always will.
thefro526
Car: BMW 325Ci & S13 Coupe
If you go to some tire places they will let you have tires that their throwing away for free. A lot of the time they have to pay to get them removed so some places will let you have them. I know there's a place by me that does a lot of tire work and the just have a Big A** dumpster that they fill up with tires and then it gets taken away on some occasions. Or you can always ask all of your friends/family if they're getting new tires and take their old ones if they're the right size.
Chukidori
naed240sx wrote:
WERD.
One thing you didn't mention that I am sure you meant to:
Running crappy rear tires also sucks because they don't grip as well. You have to take corners wider and slower because of them, and often end up swinging so wide that you loose a good line. This problem has plagued me at my last few events, but I can't afford good tires yet, so I'm just trying to make it work.
Just like in racing, The symptom of going wide is early apexing. If oyu know you are going to be wide, You should start your drift earlier , therefore hitting the apex later in your drift.
arcadia
do any here pay attention to tire wear rating? i usually get 400AA or better but just wonder if any bother with this?
drifter92
Car: 1995 Nissan 240sx Small BLock Chevy V8 5.4L
1990 Nissan 240sx Coupe SOHC Auto Wrecked Project Car
I am tired of burning through used tires in just a few runs...I went to an event and ran through 2 sets of rear tires and 1 front TOO QUICKI am going to start getting only Federal SS595's, every pro-am guy there was using the federals and this guy in a beastin' a** 350Z only used 2 sets of Federal SS595 rear tires the whole day
Joe
federals dont last any longer than most other tires.
federal and maxxis are both great, but the life isnt any greater.
wwstall
Car: S13 Silvia Blue
im using yokohama Advan Neova (ADO7) up front and eco tires in the rear. The Neova is a great drift tire.(ADO7) are maiking way for the new (ADO8) which should be just as good.
s13_maJiK
Car: s13
just make sure your running nice tires up front. Bad front tires with good rear tires=understeer like a b****
Last sunday I was running used s-drives on the front and new RT-615's on the rear and was understeering like a b**** even. Swapped the fronts and rear still ran into it a bit. Then switched to proxes up front and crap in the rear, worked like butter. I was real surprised I was understeering with the new RT's up front.
oki slide
Car: 2000 S15 SR20DET
front: federal rsrrear:nankangs or achilles atrs. both throw a good amount of smoke
ashibah83
Car: 93 SUPA BLACK COUPE
Dunlop DZ-101 Star Spec all around......
Chris28
Car: 92 s13 KA-T
I just bought some nankangs for pretty cheap, but they are on my good wheels so I probably won't be drifting with them. My last set of federals lasted a while, about a year of street driving (a few burnouts lol) and then about 5 laps on the track.
Most people I know run Federal 595's.
drifter92
Joe wrote:federals dont last any longer than most other tires.
Compared to used tires, Federals aren't much more expensive and they last 3 or 4 times as long. I get used tires for $30 and they are always old and the tread tears away from the core in just a couple runs with 160HP, I had a Federal 595 and a Kunho Ecsta on a pair of wheels and the federal still had tread and the Kumho was showing cords.
The way i see it, even for the cost, new tires make your drifting easily consistent and easy to control your car.
For the front of the car, get some quality tires preferably low profile if you can and not a stock boo boo wheel.I recently ran some 17"x7" with used 225/45 tires and they were completely amazing compared to a 15"x6.5" stock wheel with a 195/60/15 that i used before.
starkos14
Car: s14 R33*, 99 gs300(2jz-gte soon)
good points but remember, low pro tires are good to a point up front. a lot of guys are running too low pro tires on 18s up front and have lots if understeer issue. anything sticky and wide, up front is a must. i prefer 245/40/17(17x9 wheel) up front. never any problems with understeer.
drifter92
i agree, some of the people i know that were at the last drift event had horrible understeer with 18's on a s14
Return to “Nissan Drift Forum”
