tires for 7 inch wide rims
Vidra
I currently have four 7 inch wide rims w/ 215mm tires. It seems as if I could put 220's or even 225mm tires on them.... what kind of guidlines should I go by for my tire sizing? I'd like to go as wide as possible. Thanks, you can also contact me on AIM at Thermal 177 or Vidra 21.
EazyBreazy
205's imo
adrianfromthecastle
Car: 1992 Nissan 240sx
sdwyzs14 wrote:205's imo
i'm with him. 205s, no more, no less.
whiterps13
Car: white LE hatch
205's sidewalls will be perfectly square with the rim.
You can easily fit 225/45's on, but they buldge out a little bit. It doesnt look bad, just be careful. With most 17x7's (high offset) you will hit the coilovers up front on an s13 with 225's.
EazyBreazy
forgot about that part. i gotta do a better job of memorizing what you and dean say so that i can regurgitate it without errors
nismofly
Car: 89 Nissan 240SX Hatch
215's will be fine if thats what you got already...but id say 205 like everyone else
id only go up to 225 on 7's with crazy stiff sidewalls, like R-comp's or slicks
