greg_atlanta wrote:
I don't mind rotating from side-to-side via dismount/remount. Trying not to buy super premium tires, so I won't feel bad if they wear out a little faster without being able to rotate front to rear.
Guess I could put the 16 x 8.5 in front, but would be strange....
I've got 7.5s all around, with 245/50 16s. Works great- no contact, awesome handling.
Yoko AVS dBs... around $110 per if i recall. 96 load rating (again from memory)
Glenn in seattle (Gksea) has 16x8.5s with the 255s. I think Landtodd is doing the same.
My only comment on the dismount and rotate is that it can be a PITA to do, and therefore might not get done. I blow through tires so fast, that I usually only get a few rotates in anyway.
The 245 was the upper limit for me on the 7.5s...If they were 8, the 255 would be good. Aesthetically (or performance wise) I can't see any reason NOT to go with 8.5s front and rear, and 255 all around- simplifies life, adds traction and load capability to that heavy front end... now, if you don't have a line on a set of 4 that's another story...
Adam
